Community Member
rate-limiting on 3560 switch not working
I am trying to limit traffic inbound to 10Mbps on a gig interface 0/48 set to 100/full.  So I downloaded some big
files over this link and I'm able to see 30-40Mbps or more.  You can see from the show int - rate-limit command that parameters
are never showing exceented so nothing has been dropped.  What am I missing?  Thanks.
interface GigabitEthernet0/48
description ATT Link 100Mbps
no switchport
ip address 10.10.7.2 255.255.255.252
rate-limit input 10000000 10000 10000 conform-action continue exceed-action drop
speed 100
duplex full
c3560-1#sho int gi 0/48 rate-limit
GigabitEthernet0/48 ATT Link 100Mbps
  Input
    matches: all traffic
      params:  10000000 bps, 10000 limit, 10000 extended limit
      conformed 0 packets, 0 bytes; action: continue
      exceeded 0 packets, 0 bytes; action: drop
      last packet: 2167248835ms ago, current burst: 0 bytes
      last cleared 00:04:41 ago, conformed 0 bps, exceeded 0 bps
mccx-c3560-1#show int gig 0/48
GigabitEthernet0/48 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 30e4.db3c.08c5 (bia 30e4.db3c.08c5)
  Description: ATT Link to Herakles 100Mbps
  Internet address is 10.10.7.2/30
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 31/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 12487000 bits/sec, 1110 packets/sec
     12137264 packets input, 3932863552 bytes, 0 no buffer
     Received 18 broadcasts (0 IP multicasts)
1 ACCEPTED SOLUTION
Re: rate-limiting on 3560 switch not working
Try this:
ip access-list extended 101
permit ip any any
class-map match-all SHTRAFFIC
match access-group 101
policy-map POLTRAF
class SHTRAFFIC
police 10000000 10000 exceed-action drop
service-policy input POLTRAF
Best regards,
Alex
Try this:
permit ip any any
policy-map POLTRAF
class SHTRAFFIC
Best regards,
Alex
Community Member
That did it.  Thank you Alexander!
I am glad that I can help you.
Best regards,
Alex
458
