Rate limiting on a cisco 4928-10GE
Hi everyone
I have a bit of an issue with a 4928-10ge switch. Basically this switch is connected to a wan internet router which has a 1gb internet fibre connection.
Ive connected the 4928 to the end of this wan router but I need to limit each port to just 40mb each. Ive tried creating a policy map but im still getting 189mb down and over 100mb upload to some servers. Also when I go into the class map, I cant use the bandwidth command which I beleive you could use before?? Can someone please see where im going wrong with this?? Also the srr queue command doesnt work on the interface either. Thanks
System image file is "bootflash:cat4500-entservices-mz.122-54.SG1.bin"
class-map match-all class1
  match access-group 101
policy-map class1
class class1
    police 40000000 bps 1000 byte conform-action transmit exceed-action drop
interface GigabitEthernet1/1
switchport private-vlan host-association 100 101
switchport mode private-vlan host
service-policy input class1
access-list 101 permit ip any any
168
