rate-limiting or traffic shaping on 2950 switch.
I need to limit the bandwidth of Ethernet port of 2950 switch to 1 Mbps. Is there any option in 2950 for rate-limiting or traffic shaping by which the same could be possible.
1 REPLY
Re: rate-limiting or traffic shaping on 2950 switch.
There is indeed an option to do this through a policer configured through a policy-map, as described here:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea7/scg/swqos.htm#wp1045516
1 Mbps is in fact the lower bound of a configurable policer rate, so you are in luck. Bear in mind though that you have to have an EI 2950 switch in order for this to be possible. I hope this helps.
*Please take a moment to rate this post if it did indeed help you. Thank you!
Lucas
1155
