Webcast-Catalyst9k
Re: QoS and Remarking out of contract traffic to CS0
My question is say that I am using CBWFQ and matching critical data traffic with af41 in a class-map and in the equivalent policy-map giving it a bandwidth of 2Mbps.
How do I remark the out-of-contract critical data to CS0 so that it will fall into the default-class.
Thank you,
InternetB.
Re: Re: QoS and Remarking out of contract traffic to CS0
You need to write a Qos Policed map, to identify which DSCP values should ne watched for, then define the value it should be written to. Once you have this, you need to have the police action in your policy map exceed-action to policed-dscp-transmit.
HTH>
Super Bronze
To expand upon what Andrew posted, you'll need to match and classify upon ingress to accomplish what you describe. This assumes you only have one ingress interface that feeds the egress interface. If you have more than one ingess, what you describe can't be performed, although you could remark or drop out-of-contract packets within the egress policy.
e.g. one ingress to one egress
(NB: syntax likely incorrect)
class-map match-all critical-traffic-in
match ...
clas-mpa match-all critical-traffic-out
match dscp af41
policy-map ingress
class critical-traffic-in
police 2000000 conform-action set dscp-af41 exceed-action set dscp-be
policy-map egress
class critical-traffic-out
bandwidth 2000000
729
