08-14-2008 06:19 AM - edited 03-06-2019 12:47 AM
Hi All
Something strange that needs explaining. I configured an interface to a particular vlan 10 and it does not work but i change the vlan and it works.
I change the blade, the switch and still the same issue. As long as I put it in vlan 10, it will not work but put it in vlan 11 or 12 or any other vlan, it will work. What can be going wrong?
There are devices working in all the vlans.
"This is the show run"
interface GigabitEthernet?/?
no ip address
logging event link-status
switchport
switchport access vlan 10
switchport mode access
rmon collection stats
spanning-tree portfast
spanning-tree bpduguard enable
08-14-2008 06:26 AM
Quick question. Do you have vlan 10 listed under show vlan? If not, go ahead and create it and test again
08-15-2008 04:36 AM
Thanks. I think the network was just being quirky. I came in the next day and all was fine. Strange. Thanks for your help. REally appreciate it. Cheers
