Community Member
Recommand cisco Router?
1. Built-in security
2. support for wireless LAN standard 802.11/a/b/g
3. Up to two 10/100 Mbps builtin router port
4. Up to 50 VPN tunnels
5. Eight 10/100 Mbps built-in switch port with optional Power over Ethernet
Re: Recommand cisco Router?
Enjoy, this a complete cisco routers guide, take a look on the 800 series:
http://www.cisco.com/application/pdf/en/us/guest/products/ps5855/c1031/cdccont_0900aecd8019dc1f.pdf
HTH, please rate all helpful replies,
Mohammed Mahmoud.
Community Member
I'd also take a look at either the 1800 or 2800 series. The main difference is that the 1800 interfaces are built-in and cannot be changed, while the 2800 has modular slots to add and expand connectivity options.
135
