Recommend Cisco Switch for Fiber
Hi Everyone!
Can you recommend me a switch to terminate about 200 fiber links at the access layer? Only layer 2 required. Fiber has been pick due to the long runs. Cost is a concern, 100mb ports are fine.
Super Bronze
Re: Recommend Cisco Switch for Fiber
For that much 100 Mbps fiber density in a single switch, you could consider the 4500 using WS-X4248-FE-SFP cards and sup 2-plus or a 6500 with WS-X6148-FE-SFP, WS-X6524-100FX-MM or WS-X6324-100FX-MM with a sup32.
Thanks for the rely, Can you tell me what each of the line card options are and why you would pick it.
Super Bronze
Not sure I understand your question about card options or why you would pick one. You did ask for 100 fiber?
Perhaps the information your need about the cards can be found within the product's datasheets.
e.g.
WS-X4248-FE-SFP
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea.html
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet0900aecd801c5cce.html
223
