11-22-2010 12:26 PM - last edited on 03-25-2019 04:13 PM by ciscomoderator
Hi There,
I am looking for a stable release, preferably up to date ( 14.4? IOS) version for a 6513 switch running supervisor 720, the aim of the upgrade is to support a WISM card that we are installing, since the current version doesn´t support it. But also I am looking for a stable release that will bring us up to date with our core infrastructure.We run a collapsed Core/distribution in a DC running eigrp,
I would like to know if somebody can have some usefull experience or tips regarding a suitable software image to choose for such an upgrade..the switch runns eigrp, quality of service, some policy routing..sh ver, sh modules below...
Thank you
Martin
IOS (tm) s72033_rp Software (s72033_rp-JK9SV-M), Version 12.2(17a)SX3, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 03-Mar-04 20:36 by cmong
Image text-base: 0x40008FBC, data-base: 0x421CE000
ROM: System Bootstrap, Version 12.2(14r)S9, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-JK9SV-M), Version 12.2(17a)SX3, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
IPSOS-NA-CORE-01 uptime is 2 years, 37 weeks, 1 hour, 34 minutes
Time since IPSOS-NA-CORE-01 switched to active is 2 years, 37 weeks, 1 hour, 43 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 14:39:10 EST Sat Mar 8 2008
System image file is "sup-bootflash:s72033-jk9sv-mz.122-17a.SX3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. WS-C6513 (R7000) processor (revision 1.0) with 458752K/65536K bytes of memory.
Processor board ID SAL0803SY8Q
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
14 Virtual Ethernet/IEEE 802.3 interface(s)
316 Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
If
cisco
65536K bytes of Flash internal SIMM (Sector size 512K).
Standby is up
Standby has 458752K/65536K bytes of memory.
show module
#sh module
Mod Ports Card Type Model Serial No.
1 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAL1115LCFG
2 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAL1201BZHS
3 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAL1115L9WE
4 16 SFM-capable 16 port 1000mb GBIC WS-X6516A-GBIC SAL0809VC7H
5 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAD080303VN
6 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAD080403J0
7 2 Supervisor Engine 720 (Active) WS-SUP720-BASE SAD081008US
8 2 Supervisor Engine 720 (Hot) WS-SUP720-BASE SAD081102DY
9 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL08486CEH
12 8 Network Analysis Module WS-SVC-NAM-2 SAD072300CL
Mod MAC addresses Hw Fw Sw Status
1 001b.5329.d8c0 to 001b.5329.d8ef 11.1 7.2(1) 8.2(0.56)TET Ok
2 001e.be51.f678 to 001e.be51.f6a7 11.3 7.2(1) 8.2(0.56)TET Ok
3 001b.0cd5.9d5c to 001b.0cd5.9d8b 11.1 7.2(1) 8.2(0.56)TET Ok
4 000f.343b.0db8 to 000f.343b.0dc7 3.0 7.2(1) 8.2(0.56)TET Ok
5 000f.235a.c600 to 000f.235a.c62f 7.0 7.2(1) 8.2(0.56)TET Ok
6 000f.2320.3a50 to 000f.2320.3a7f 7.0 7.2(1) 8.2(0.56)TET Ok
7 000d.2910.31a0 to 000d.2910.31a3 3.1 7.7(1) 12.2(17a)SX3 Ok
8 000f.237b.b338 to 000f.237b.b33b 3.1 7.7(1) 12.2(17a)SX3 Ok
9 0012.4302.52c0 to 0012.4302.52ef 2.1 12.2(14r)S5 12.2(17a)SX3 Ok
12 0003.feab.c12c to 0003.feab.c133 2.0 7.2(1) 3.5(1b) Ok
Mod Sub-Module Model Serial Hw Status
5 Cisco Voice Daughter Card WS-F6K-VPWR-GE SAD080103K2 1.0 Ok
6 Cisco Voice Daughter Card WS-F6K-VPWR-GE SAD080203DG 1.0 Ok
7 Policy Feature Card 3 WS-F6K-PFC3A SAD081009EG 2.2 Ok
7 MSFC3 Daughterboard WS-SUP720 SAD08100946 2.2 Ok
8 Policy Feature Card 3 WS-F6K-PFC3A SAD081009J6 2.2 Ok
8 MSFC3 Daughterboard WS-SUP720 SAD0811015C 2.2 Ok
9 Centralized Forwarding Card WS-F6700-CFC SAL08465Y4H 2.0 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
4 Pass
5 Pass
6 Pass
7 Pass
8 Pass
9 Pass
12 Pass
11-22-2010 12:51 PM
There is no 14.0 code for 6500's . All versions are 12.2 versions . Latest are the 12.2 SXH and SXI versions . You will have to use the feature navigator to determine which version bests suites your needs and what version supports a WISM . Also verify you have enough flash and RAM to accomodate the newer versions. The newer versions are a "lot" bigger than the version you are using , some are closing in on 100 meg for file size.
11-23-2010 06:32 AM
Thanks for your answer, in fact I meant to write 12.4 and not 14.0!!
11-23-2010 03:23 PM
quote: Thanks for your answer, in fact I meant to write 12.4 and not 14.0!!
No 12.4 either only 12.2 versions . I would say go with the other poster and go with a safe harbor version that will support your WISM . Safe harbor testing acceptance usually means it is a stable release version ok to use in almost all circumstances...
11-22-2010 12:53 PM
You might want to check out the Safe Harbor recommendation page.
http://www.cisco.com/en/US/netsol/ns504/networking_solutions_program_category_home.html
HTH,
jerry
11-23-2010 10:23 AM
I work for an ISP, we've probably got 100 Sup 720's out there running this..
disk0:c7600s72033-advipservicesk9-mz.122-33.SRD4.bin
Do a bug scrub on that, see if there's anything you do with your box that could possibly be affected by known-issues...
11-23-2010 10:40 AM
If you read the original post correctly, the original poster is using a Catalyst 6500 not 7600. Hence, the SRD code will not work.
jerry
