Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Record a Ethernet port on a Cisco 2950
Hi All,
I have several data conversion devices with a 2950 switch being used to route two available multicast addresses to three "destination" ports on the switch.
Using "Expect" scripting I am able to login into the switch and configure each port to select one but not both of these addresses.
What I would like to know is there a 2950 command(s) I can use to record the selected multicast address going out of any of the destination ports.  I would you this result to run a script.
Cisco 2950
IOS Version 12.1(22)EA1
Using Mulicast VLAN Registration (MVR) for the switch program.
Multicast addresses: 239.1.1.3 & 239.1.1.4
Thanks.
Jeff
290
