Recover Deleted Configurations
I am removing configurations off of old cisco switches. Is there possibly a way to recover a configuration after it has been deleted? Is there a special procedure for cleaning switches so that nobody can recover old data?
Re: Recover Deleted Configurations
U can backup ur configuration to the tftp server.after removing the configurations u an still restore them from tftp server.
u can erase u r nvram to permanently delte the configuration.
Mahmood
I don't need to keep the configurations, I want to make sure that nobody else can recover them.
Just erase ur nvram and reload the switches.the switch is going to factory default settings.No one will be able to recover it.
Mahmood
Thanks Mahmood.
I was pretty sure that by erasing the file nobody would be able to recover any of the old configurations. I just wanted to make sure.
If you switch support this command.
"no service password-recovery"
Purple
I would check flash, bootflash,slot0, disk 0 etc and make sure no one saved any configs in there , if they did then you must delete and squeeze if needed . Write erase will get rid of the current config but a lot of times people will download configs in flash for different reasons .
Write erase should permanently dump configuration stored in nvram.
If you need to wipe configurations/files that were stored to flash you should use the squeeze command.
squeeze device: (Example, flash:)
That is, once the files have been deleted.
265
