Recover router
Dear All,
While doing a password recovery on 2691 router, i accidentally changed the config register value to 0x2162 instead of 0x2142. Now i get all junk while booting the router.
Is there a way where i can undo this mistake?
Thanks a lot
Gautam
Re: Recover router
Yes, try different baud rates on the terminal until you get the right one. If I have calculated right, 19200 should do the trick.
http://www.cisco.com/en/US/partner/docs/routers/access/2600/hardware/installation/guide/2600appC.html
Kevin Dorrell
Luxembourg
Silver
Re: Recover router
Hi Gautham ,
Chnage the baud rate starting from Min. value to Max.value and check whether you are getting rommon mode at one particular value.
satish
Re: Recover router
Thanks a lot for your kind inputs. I will let you know.
201
