10-07-2009 07:22 PM - edited 03-06-2019 08:02 AM
Hi friends,
I have a cisco 6509 with CatOS. Can you please advice the command line to view the crashinfo file. I tried to get thru tftp; but it's not readable format. Please advice.
Thanks!!
10-07-2009 07:27 PM
Please refer to this URL
http://www.cisco.com/en/US/products/hw/routers/ps167/products_tech_note09186a00800a6743.shtml
Edison
10-07-2009 07:52 PM
Hi Edison,
Thanks for the reply!!
The command 'more' is not working in CatOS. Checked this is working on cisco IOS. Please advice if any command to check in CatIOS. Thanks.
10-07-2009 08:38 PM
Copy the crashinfo into your computer (using TFTP)and use Notepad or Wordpad to view it.
10-07-2009 09:08 PM
Hi..
We did that. When opening in wordpad, it's full of Jung characters. Even Cisco TAC engineer to whom I sent this file said the same thing.
