Recovery missing or corrupted IOS of Cisco 2960 Catalyst Switch
Dear Team,
I have Cisco 2960 48P switch, It is keep getting restarted and config was erased.
when I tried to run the IOS from hypertrm in room mode, I am getting below error..
My doubt is, is there any issue with hardware & what is the cause of for below error
suggest me, is there any option to upgrade the IOS?
switch: flash_init
Initializing Flash...
flashfs[0]: 0 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 1024
flashfs[0]: Bytes available: 32513024
flashfs[0]: flashfs fsck took 9 seconds.
...done Initializing Flash.
switch: copy xmodem: flash:c2960-lanbasek9-mz.122-50.SE5.bin
Begin the Xmodem or Xmodem-1K transfer now...
CCCCBB0BB0................flashfs[0]: filesystem marked down.  Use "fsck" to rec
over.
flash:c2960-lanbasek9-mz.122-50.SE5.bin: interrupted system call
switch:
Thanks & Regards, Srinivas. N.
1 REPLY
Hall of Fame Super Gold
Error message means your BIN
Error message means your BIN file is corrupt.  You need to download again from the Cisco website.
862
