Rectification of loop & broadcast problem
Arijit Das
Myself Arijit. I need your help regarding following matter.
If suppose one workstation in a large LAN generates  broadcast or creates loop then what is the quickest and the most easiest way to identify and rectify that.
Please suggest.
5 Replies 5
Ganesh Hariharan
Please suggest.
Hello Arjit,
Wireshark or Ethereal are best tool to capture and identify broadcast traffic in LAN.
Hope to Help !!
Ganesh
Rate if it Helps ...
Arijit Das
Hi Ganesh,
Thanks for the reply.
Could you please explain the procedure in details.
Arijit
Hi there,
the programs ganesh mentioned earlier are not from cisco, they are network monitoring applications, u use them to monitor network traffic pattern and identify traffic types and source / destinations.
you could find additional information in their respective website.....: http://www.wireshark.org
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
Arijit Das wrote:
Hi Ganesh,
Arijit
Hello Arjit,
In order to do the above implemenation you need to install the wireshark on your system and run on one of the adapter to see the traffic pattern.
Check out the below link for installtion for wireshark
http://www.petri.co.il/wireshark-ethereal.htm
Hope to Help !!
Ganesh
Hello Ganesh,
Thanks for te reply.
Got your point. One more thing i want to ask you that what frame in wireshark is to identify that there is broadcast or loop in the network.
And what will be the sourse and destination of that frame.
Arijit
