Redistribute EIGRP into BGP
Hi All
Kindly I need to check if I have an active static route on router and in the same time the route in the EIGRP topology table but 0 successor . If I tried to redistribute EIGRP routes into BGP I need to check if this route will be redistributed into BGP or not
show ip eigrp topology | include 192.168.10.16
P 192.168.10.16/32, 0 successors, FD is Inaccessible
show ip route 192.168.10.16
Routing entry for 192.168.10.16/32
  Known via "static", distance 1, metric 0
* 10.10.204.1
Can you paste us the config
Can you paste us the config of the device?
hi, Route will only be
hi,
Route will only be redistributed when route is installed into routing table from the routing protocol which is being redistributed. To redistribute the network 192.168.10.16/32, you need to redistribute static route under BGP.
Akash
76
