Redistribute Static Routes into OSPF
akhran1974
I have three routers (RouterA, RouterB and RouterC) connected to the same LAN.
RouterA : 10.1.1.1/24
RouterB : 10.1.1.2/24
RouterC : 10.1.1.3/24
Router A is not running OSPF, but RouterB and RouterC are in the same ospf area 0. A static route is inserted into RouterB with the RouterA as the next hop gateway:
RouterB#
ip route 10.2.2.0 255.255.255.0 10.1.1.1
router ospf 1
redistribute static subnets
When this static route is advertised to RouterC via the redistribute command, RouterC's routing table is showing:
10.2.2.0/24 [110/20] via 10.1.1.1(Router A), Vlan1
Shouldn't it be
10.2.2.0/24 [110/20] via 10.1.1.2 (RouterB), Vlan1
instead, since the route was advertised to RouterC by RouterB?
Thanks !
16 Replies 16
You are totally confusing.
One thing is sure, if there is no intra-area or inter-are path to the FA (here 10.1.1.1), then that external LSA will be ignored.
But you are saying, you have enabled OSPF on 10.1.1.2 interface in RouterB, in that case, RouterB should have advertised 10.1.1.0 subnet to other routers, in that case RouterC should see 10.1.1.1 through OSPF.
I think you have missed something.
Kindly describe about your current topology and ask questions.
Vijaybabu
Hi Vijaybabu,
The topology is still the same as mentioned previously:
RouterA
|.1
|------------------------LAN1(10.1.1.0/24)
|.2 |.3
RouterB RouterC
|.1 |.2
-------------------------LAN2(192.168.1.0/24)
|.3
RouterD
10.1.1.0/24 is a connected interface on RouterC. So if I understand correctly, the route to 10.2.2.0/24 was dropped in RouterC after enabling ospf on 10.1.1.2 interface on RouterB because in RouterC, the route to 10.1.1.0/24 is not learnt through OSPF and/or OSPF is not running on the 10.1.1.3 interface. Correct me if I'm wrong...
Thanks !
