Redistributing EIGRP using route-map Nexus 5596 L3
Hi All:
this is a Nexus 5596 L3 with the latest code:
It looks like the deny statement is not working as I can see  all routes I am redistributing. I even did a deny on a specific route and I still see it in the routing table on another router in the autonomous system.
The same below works fine on IOS platform
ant help appreciated before I open a case.
ip access-list ACL-ALLOW-STATIC-TO-EIGRP
  10 remark test
  20 remark test2
  30 permit ip 55.55.55.1/32 any
  40 permit ip 55.55.65.1/32 any
  50 permit ip 55.55.75.1/24 any
  60 deny ip any any
route-map ROUTEMAP-ALLOW-STATIC-TO-EIGRP permit 10
  match ip address ACL-ALLOW-STATIC-TO-EIGRP
route-map ROUTEMAP-ALLOW-STATIC-TO-EIGRP deny 20
router eigrp client
  autonomous-system 1
   redistribute static route-map ROUTEMAP-ALLOW-STATIC-TO-EIGRP
  default-information originate
ip route 0.0.0.0/0 10.121.1.1
ip route 55.55.55.1/32 10.121.1.18 name test1
ip route 55.55.65.1/32 10.121.1.18 name test2
ip route 55.55.75.1/32 10.121.1.18 name test3
ip route 55.55.85.1/32 10.121.1.18 name test4
ip route 55.55.95.1/32 10.121.1.18 name test5
1 ACCEPTED SOLUTION
Re: Redistributing EIGRP using route-map Nexus 5596 L3
It is listed in the link in my first post:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/unicast/5_0_3_N1_1/l3_rpm.html#wp1088438
If you read the route-map section, it states that prefix-list is used for match based on an address or range of addresses. And ACL is used for a number of IP packet fields such as the following:
- Source or destination IPv4 address
- Protocol
- Precedence
- ToS
Can you tell me which bug you are waiting for 5.1(3)?
jerry
You cannot use IP access-list inside a route-map to perform redistribution in NXOS. You will have to use prefix-list instead:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/unicast/5_0_3_N1_1/l3_rpm.html#wp1071167
However, N5500 NXOS 5.1(3)N1(1) has an IP prefix-list bug which the ip prefix-list command is not available in the CLI (I cannot share the bug ID since it is still internal), you should downgrade it to NXOS 5.0(3)N2(2b) instead.
HTH,
jerry
First of all thanks for your reply. Very much appreciated.
I have been waiting for 5.1(3)N1(1)  for 2 months now for a bug fix.
It is hard to fallback. Is this documented somewhere that I cannot use IP ACL for routemap to do redist?
- Protocol
- Precedence
- ToS
jerry
thanks. The bug was the management SVI which is now a new feature in the new code.
Thanks for the info and points.
jerry
1951
