02-16-2012 07:58 AM - edited 03-07-2019 04:59 AM
I'm looking to redistribute static routes in to OSPF on a Nexus 7k. To do this I'll be using a route-map with a match statement. My question is can you match routes using an ACL, a prefic-list or both. The reason that I ask is that in some docs I've read it states the following:
IP access lists—(For policy-based routing only). Match based on source or destination IP address,
protocol, or QoS parameters.
This tends to indicate that you can't use IP access lists for the match criteria for redistribution. Can anyone confirm this from their experience?
Malcolm
02-16-2012 05:00 PM
I just did some testing of this... and the documentation appears to be correct. I couldn't get proper redistribution when using route-map with ACL. I set up an ACL that didn't permit anything, and all my static routes were redistributed. When I used a prefix list, it behaved as expected.
See my output below for reference.
NexusLab(config)# do show run | b route-map
route-map test permit 10
match ip address redistribute-static
route-map test2 permit 10
match ip address prefix-list redist-prefix
NexusLab(config)# do show ip access-l redistribute-static
IP access list redistribute-static
20 deny ip any any
NexusLab(config)#
NexusLab(config)#
NexusLab(config)#
NexusLab(config)# do show ip prefix-list
ip prefix-list redist-prefix: 1 entries
seq 5 permit 1.1.1.1/32
NexusLab(config)#
NexusLab(config)#
NexusLab(config)#
NexusLab(config)# do show ip route static
IP Route Table for VRF "default"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
1.1.1.1/32, ubest/mbest: 1/0
*via Null0, [1/0], 00:12:21, static
3.3.3.3/32, ubest/mbest: 1/0
*via Null0, [1/0], 00:05:59, static
NexusLab(config)#
NexusLab(config)#
NexusLab(config)# router ospf 44
NexusLab(config-router)# redistribute static route-map test
NexusLab(config-router)# do show ip ospf data external self
OSPF Router with ID (10.100.100.100) (Process ID 44 VRF default)
Type-5 AS External Link States
Link ID ADV Router Age Seq# Checksum Tag
1.1.1.1 10.100.100.100 612 0x80000002 0xe49d 0
3.3.3.3 10.100.100.100 7 0x80000002 0x88f1 0
NexusLab(config-router)# redistribute static route-map test2
1.1.1.1 10.100.100.100 627 0x80000002 0xe49d 0
Hope this helps.
Matt
02-17-2012 01:44 AM
Hi Matt
So from your output it looks like the access-list isn't used and the route-map matches all statics and redistributes them. Looks like I'll be using prefix-lists then.
Thanks for testing that out
Malc
