Redundancy with Sup720
I am having with 2 Sug720 -10G modules for a 6509 chassis. The standby supervisor is coming up as unknown status and the reduancy is showing as down when i do a show redundancy state.. The config I have applied is below
redundancy
keepalive-enable
mode sso
main-cpu
auto-sync running-config
Am I missing a command? Is anybody having similar issues with these supervisor modules?
Re: Redundancy with Sup720
Derek,
Are you able to console into the standby supervisor and make sure it not stuck in rommon.
HTH,
Mark
the second supervisor is stuck in rommon.
Is tehre a way around this?
You can type the command "boot". I would also make sure the config-register is correct on your standby supervisor to make sure it doesn't sit in rommon upon reboot. type "confreg 0x2102" in rommon, then type "reset".
Mark
i have tried this and this does not boot the switch. I presume the image is corrupt. Is there a way around this? can i not copy the image from the primary sup to the backup sup
Is there a command to do this?
Not from rommon. what is the output of "dir bootflash:"? Also if you have a compact flash card you can copy the IOS from the primary and boot the standby from the CF card. If not you may need to use xmodem to load a bootable image from rommon.
Mark
175
