04-20-2007 09:45 PM - edited 03-05-2019 03:35 PM
what is the best practice design of having a redundant core switch?
the scenario is;
2 x 6500
2 edge switches in each floor
thanks.
04-20-2007 11:37 PM
The best design practice is using 2 fibers/ethernet links from each edge switch and connect the links to each 6500 at the core.Connect inturn both the 6500 to make a traingle. Use the PVST and MHSRP to do the STP load-balancing and L3 traffic load-balancing using MHSRP.
Another option would be to run connect both the edge switches and then inturn run a single link from each edge switch to connect to each core 6500.Again run the STP and MHSRP load-balancing at the core.
HTH,Please rate if it does.
-amit singh
04-21-2007 06:21 AM
is it possible for you to give me a sample config of both the core switches, configured for a single floor having 2 edge switches.
thanks
