Redundant interface pairs like ASA on routers?
I'm designing and configuring a new network and I would like to connect one router with two interfaces to the same spanning tree domain (a couple of switches). A third interface is going to another subnet.
I would like to have the two interfaces to be redundant and provide subsecond failover. So a BVI with spanning tree on the router is not really an option.
Is it possible to configure redundant interface pairs like ASA 8.0 on a router? Or is there another way to accomplish this?
Re: Redundant interface pairs like ASA on routers?
So two router interfaces connected to the same switch? or each router interface connected to a different switch?
The two interfaces are connected to different switches, but connected to the same layer 2 domain / vlan / spanningtree domain.
You could do it with bridging on the router:
bridge 1 protocol ieee
bridge irb
interface FastEthernet0/1
bridge-group 1
interface FastEthernet0/2
bridge-group 1
interface BVI 1
ip address 10.1.1.1 255.255.255.0
Andy
Yes this is an option, but I would like to have subsecond failover between the links.
Is it possible to configure uplink fast between these links?
You could tune STP to try and achieve these kinds of times, however I think you want to be looking at alternative designs.
Dual routers running HSRP/GLBP is where I would be looking.
Andy
374
