Webcast-Catalyst9k
Redundant IPS with PBR NAT
Hi There,
I am trying to create redundant link for "client", see attached diagram.
What i am trying to achieve is if client, ip address 172.20.200.1 will try to go to internet (in my scenario lo 4.4.4.4), it should go via isp "HSO" and address translated to 217.196.0.1, if this ips is not available then it should go via "backup" ips and have address translated to 192.168.0.1.
My config on router R7:
ip sla monitor 1
type echo protocol ipIcmpEcho 4.4.4.4 source-interface FastEthernet1/0
frequency 5
ip sla monitor schedule 1 life forever start-time now
track 1 rtr 1
interface FastEthernet0/0
ip address 172.20.200.2 255.255.255.0
ip nat inside
ip virtual-reassembly
ip policy route-map pbr
speed 100
full-duplex
ip address 217.196.0.1 255.255.255.0
ip nat outside
speed 100
full-duplex
interface FastEthernet2/0
ip address 192.168.0.1 255.255.255.0
ip nat outside
speed auto
full-duplex
no ip http server
no ip http secure-server
ip route 4.4.4.4 255.255.255.255 FastEthernet1/0
ip route 4.4.4.4 255.255.255.255 FastEthernet2/0 10
ip nat translation icmp-timeout 1
ip nat pool hso 217.196.0.1 217.196.0.1 netmask 255.255.255.252
ip nat pool backup 196.168.0.1 196.168.0.1 netmask 255.255.255.252
ip nat inside source route-map backup pool backup overload
ip nat inside source route-map hso pool hso overload
access-list 1 permit 172.20.200.0 0.0.0.255
route-map backup permit 10
match ip address 1
match interface FastEthernet2/0
route-map pbr permit 10
match ip address 1
set ip next-hop verify-availability 217.196.0.2 1 track 1
set ip next-hop 192.168.0.2
route-map hso permit 10
match ip address 1
match interface FastEthernet1/0
NAT works with above config and i can ping 4.4.4.4 from client router, when i shutdown a lin between "internet" router and "hso" router, ping stops and traffic is not natted to backup isp.
I guess my problem is that my static route to 4.4.4.4 via fa2/0(backup isp) does have distance of 10 so it never ends up in routing table but if i give it default metric of 0 then my "track 1" goes up and down ....
unfortunately I cannot use default route 0.0.0.0
any help much appreciated
Kind regards
Marcin
128
