redundant link issue
Hi, I am having a redundant design upgrade request from the client.
Here is the scenario, location A is the servers room, location B is a remote site. There is a 3560 switch at location A and location B and they are connected to ISP WAN at this moment. ISP does the routing and switching.
I need to build a direct connected microwave data link between location A and B as a redundant link. Please check the diagram
On the switch at location B, Gi0/1 is connected to ISP router. Fa0/47 is connected to microwave data link switch. I need to adjust the configuration of the switch such that if the G0/1 interface on the VTS switch is lost then it will pass data from port 47. In this case, how do I change my configure?
Dennis
1 REPLY
Bronze
Are you using your 3560's as
Are you using your 3560's as routers? Or are you just passing everything to your ISP?
Maybe post the configs for both your 3560's?
105
