REdundant sup 720 failover ....pinnacle error?
Hello gurus,
We have redundant 720s ina 6509-E
Earlier we had the a failover to secondary. - I see this in the show switch plat hard asicreg - for module 5, what are those errors? couldnt find anything.
Slot 5
--- remote command switch show plat hard asicreg PINNACLE slot 5 port 1 error-co
unters print-non-zero ---
PINNACLE 5/1
06F: PI_CI_S_CBL_DROP_REG = 0002
--- remote command switch show plat hard asicreg PINNACLE slot 5 port 2 error-co
PINNACLE 5/2
016F: PI_CI_S_CBL_DROP_REG = 0002
--- remote command switch show plat hard asicreg PINNACLE slot 5 port 3 error-co
--- remote command switch show plat hard asicreg PINNACLE slot 5 port 4 error-co
Slot 6
--- remote command switch show plat hard asicreg PINNACLE slot 6 port 1 error-co
--- remote command switch show plat hard asicreg PINNACLE slot 6 port 2 error-co
--- remote command switch show plat hard asicreg PINNACLE slot 6 port 3 error-co
--- remote command switch show plat hard asicreg PINNACLE slot 6 port 4 error-co
1 ACCEPTED SOLUTION
Bronze
Re: REdundant sup 720 failover ....pinnacle error?
The error message in the log file is an ipv6 mulicast syslog seen with ipbase images and this message does not affect any of the functionalities of the device.
1 REPLY
Bronze
584
