Webcast-Catalyst9k
Redundant sup 720 is in disabled state.
My 7609 router has 2 no of sup720.But only one is active,the other one is not in redundant state.Says it is disabled.
I connected the console to the second SUP720 , but it is in rommon mode.How can I go forward.It is in a live environment so I have to be very carefull, while doing anything.Please help me in this.
eng-lab-rtr1#sh redundancy
Redundant System Information :
Available system uptime = 1 hour, 25 minutes
Switchovers system experienced = 0
Standby failures = 0
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = sso
Operating Redundancy Mode = sso
Maintenance Mode = Disabled
Communications = Down Reason: Simplex mode
Current Processor Information :
Active Location = slot 5
Current Software state = ACTIVE
Uptime in current state = 1 hour, 24 minutes
Image Version = Cisco Internetwork Operating System Software
IOS (tm) s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(18)SXD6, RELEASE S
OFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 17-Aug-05 18:13 by evmiller
BOOT = sup-bootflash:,1
CONFIG_FILE =
BOOTLDR =
Configuration register = 0x2102
Peer (slot: unavailable) information is not available because it is in 'DISABLED
' state
Anil.
Re: Redundant sup 720 is in disabled state.
Anil,
As the Sup is in rommon that's why it is stated as disabled for redundnecy. To take it, first check whether you are in SUP rommon or the MSFC rommon.We have to also check why the sup is in rommon, is it some software issue.
Please try the following steps:
1:Connect the console to the sup and reload it.
2.The moment you see that it is booting, press CTRL+Break and try to break into Sup's rommon.
3.Once you rae in rommon, Check "dir bootflash:" and see if the file is located there.
4.If the file is not there, then this the the problem and that's why the sup is in rommon.Then try to Xmodem the file or if you have a PCMICA slot then try to boot is from there.
5.If file is there, then do the following:
rommon>set
This will command will let us know the bootpath for the sup.If he boot path is not there then do the following
rommon> BOOT:=sup-bootflash:
rommon> Sync
Check the bootpath again
rommon>set
6. If the bootpath is there, then try to boot the sup manaually
boot sup-bootflash:
7 Once the sup is back the config files will get sync up and it should be Ok after that.
Let us know your findings after this and then we will take if from there.
HTH,
-amit singh
This should be a "Forum Sticky Post" along with the "Magic Number" :-)
3851
