Community Member
Redundant SUP Engine V fails to synchronize
Hello Everyone,
I'm trying to configure an interface on the switch but the terminal/telnet stalls for a few moments and shows the following message:
11w2d: %HA_CONFIG_SYNC-3-LBL_CFGSYNC: Unable to sync due to IPC timeout or IPC rsp loss with current timeout(150) in second
11w2d: %HA_CONFIG_SYNC-3-LBL_CFGSYNC: Unable to sync cfg-changed cmd(int GigabitEthernet3/1) to standby
11w2d: %SYS-5-CONFIG_I: Configured from console by administrator on console
Need help on this. I can't configure anything on the switch, especially on the interface level.
Please anyone, badly need your help.
Ralph
Community Member
Re: Redundant SUP Engine V fails to synchronize
What OS version are you running? In the short term, have you tried simply removing the redundant sup so that you can make changes?
Community Member
here is my OS:
Version 12.2(40)SG, RELEASE SOFTWARE (fc2)
About removing the redundant SUP, i don't want to try it out first until I am able to use all other means to make the synch work. Is this some kind of a bug or something?
Hall of Fame Super Gold
Have you tried using a different IOS?
Community Member
nope, not yet.. That may be our first step on the troubleshooting. I will give you feedback after i have done this.
831
