11-08-2011 03:01 AM - edited 03-07-2019 03:16 AM
I have an 4507R with one Supervisor Engin V card. I want to add a redundant supervisor engin card to my 4507R Chassis.
Can i use supervisor engin 6-E for redundant or i must use Supervisor Engin V ?
Witch model of Supervisor Engines Supported with this chasis?
Solved! Go to Solution.
11-08-2011 04:54 AM
Ali,
You need to have the same exact sup modules and IOS in the chassis, if not, SSO will not work.
11-08-2011 05:41 AM
As above said, you need to have same supervisor engines and same ios versions on both.
4507 will support both V and 6-E but when you need to keep two supervisor enginers then you must have same type/model of both.
See the below link for more information:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/prod_white_paper0900aecd806ed38a.html
Please rate the helpfull posts.
Naidu.
11-08-2011 04:54 AM
Ali,
11-08-2011 05:41 AM
Naidu.
