Bronze
redundant switch supervisors
Hi every body!
I was reading about redundancy in switch supervisors.
There are different modes:
1) route processor redundancy(RPR)
2)Route processor redundancy(RPR+)
3)stateful switchover (SSO)
q1)I understand how these modes but my question is why one want to use any other mode but sso as fail over time is less than a second compared to other modes ?
q2) Should both supervisors be same?
Thanks a lot!
Hall of Fame Super Silver
Re: redundant switch supervisors
Hello Sarah,
q1) SSO requires identical supervisors, identical ios image and newer IOS image (it has more tight requirements) so there can be cases where RPR or RPR+ can be used but SSO cannot
q2) for SSO they need to be exactly the same model, RPR and RPR+ have lesser requirements
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/46sg/configuration/guide/RPR.html#wp1116237
Hope to help
Giuseppe
Bronze
thanks a lot Giuseppe!
My book says
For RPR+ ios must be of same release. How about sup? they should be same as well?
The sups' have to be the same as well.
regards,
-amit singh
Hi ,
There are several modes , but every mode has its own unique circumstances. The fastest mode is not always the best mode
1)SSO enables subsecond convergence , but some state tables like HSRP encounters problems during the switchover. For example if your supervisors or RPs switch faster than your HSRP timeout , you will definetely experience a switchover in the HSRP state as well.
2) The Supervisors / RPs must be the same.
142
