Reg:2924xl switch
Dear sir,
Iam having 2924 switch in that frontpanal system light is glowing orange colour and 4 ports r glowing orange colour plz give reply why it was .
srini
9246571397
Re: Reg:2924xl switch
It seems that you have lost an ethernetcontroller. The amber system LED is an indication for the detection of a failure.
From the sh ver output I read that the system thinks it has only 26 ports, the total amount should be 30 (24 + 4 + 2).
Being a hardware failure, there will not be much to do about this, the 2924 series is old and forgotten.
Leo
An Amber system LED means that it is not functioning properly. It generally means that the device has failed the POST which could be due to incorrect image.
The other ports if amber could be due to the following reasons
It is initializing
It was disabled by management or by an address violation
It was blocked by Spanning Tree Protocol
Narayan
139
