REG: Skype
Can anyone please suggest me how we can allocate 1mbps to Skpye application and priotize the vioce on Skype.
Re: REG: Skype
HI Mohit, [Pls RATE if HELPS]
Command:
ip nbar protocol-discovery.
This will enable nbar discovery on your router.
Cisco released IOS version 12.4 (4) T. Cisco introduced much awaited Skype classification in NBAR.
NBAR configuration for Skype packets:
class-map match-any p2p
match protocol skype
policy-map Allow-p2p
class p2p
bandwidth 1024
int FastEthernet0
description WAN_INterface
service-policy input Allow-p2p
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
Re: REG: Skype
I am not sure about your platform where you need to do this
As per Cisco 12.4(4)T Cisco IOS XE Release 2.1 supports classification of skype traffic using NBAR
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/clsfy_traffic_nbar.html#wp1052372
Narayan
Re: REG: Skype
thanks for the reply
Yes on Release 12.4(4)T. Cisco software supports Skype 1.0, 2.5, and 3.0
can we prioritize the Vioce traffic on Skype or its by default takes priority ?
if has to configured can you plese suggest.
Re: REG: Skype
You will have to prioritise the entire class
Narayan
455
