Community Member
reg:suggession
Dear experts,
1. Do the above mentioned Routers series of 1841,2821 and 3825.Supports
data
along with voice ?.
2. If so then which type , whether FXO or FXS or both?
3. If they do support voice and in FXO mode then up to how many lines ?
4. Is Exchange necessary in case of a FXO?
In case the above mentioned Routers do not support FXO, FXS then kindly
suggest the router series that support the FXO and FXS .If it doesnt support why it wont support (reason)
Thanks&Regards
srini
1 REPLY
Re: reg:suggession
Srini,
1. 1841 doesnot support voice.
2. Both
3. Depends on the over-all router capacity with HWIC/NM modules
4. Nope, you can terminate the PSTN line directly on it.
-amit singh
105
