ā08-28-2012 12:21 AM - edited ā03-07-2019 08:34 AM
We are planning to do IOS upgradation in our Switches . Please suggest recommended IOS versions.
Currnet IOS
c3560-ipservices-mz.122-35.SE5.bin
c2960-lanbase-mz.122-35.SE5.bin
c3560-ipbase-mz.122-35.SE5.bin
Cheers,
Rammanokar.
ā08-28-2012 12:27 AM
Unless your company has a policy in place restricting the latest version then I say get the current for each switch.
Sent from Cisco Technical Support Android App
ā08-28-2012 12:38 AM
I run fine with 12.2.55-SE6 (just upgraded some devices last week) which at least for the 2960 is not the newest software. But in the past I had much more luck with releases that hae a higher number behind the "SE" as these already got some bugfixes after new features were introduced.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
ā08-28-2012 04:14 AM
For both 3560 and 2960 implement 12.2.58 or 12.2.55. no pint to implement the 12.2.35
Alessio
ā08-28-2012 08:07 AM
Hello. There any reason for this IOS upgrade ?
ā08-28-2012 02:03 PM
Audit.....:-(
ā08-28-2012 03:11 PM
For Layer 2-only, 12.2(55)SE5 and SE6 are not bad. Currently using 15.0(2)SE for layer 2. So far so good.
For Layer 3, then there's no substitution to 12.2(55)SE5 or SE6.
Avoid, at all cost, 12.2(58)SE altogether. 15.0(1)SE3 is also not bad but I had about two weeks use of this version before upgrading to 15.0(2)SE.
IMPORTANT: Read the respective Release Notes of the IOS you are going to use.
ā08-28-2012 11:02 PM
Hello again.
In my opinion something which is working do not change , unless there is a good reason like yours.
I have just install DMP players in my network and there the was the need of medianet. Medianet , i am not sure but i think is supported from 12.2(55) and up, so i was upgraded the ios to the version 15.0(1)SE3. Until now these are working perfectly.So I suggest this........15.0(1)SE3
