Bronze
relation between clock rate and port speed
Hi every body!
Say we have this set up r1s0---------dsu/csu------T1-----------------csu/dsu---r2
Dsu/csu say is using internal clock. what clock rate should be configured so that r1 can send data at 1.544 Mpbs.
To put it another way, How do we determine the clock rate for a port?
Thanks a lot!
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: relation between clock rate and port speed
Hello Sarah,
the relationship is 1 to 1 in this case: the clock rate has to be set to 1544000 to allow the router to use a full T1 speed.
Edit:
there is the other thread where Victor, Edison and Vuyan have provided useful answers with a lot of detailed information you can find a better answer there
Hope to help
Giuseppe
Hall of Fame Super Bronze
Sarah,
The clock rate command is used on DCE serial interfaces, not under internal CSU/DSUs.
Internal CSU/DSUs use the 'timeslot' concept:
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_s2.html#wp1011734
If you purchased a T1, you will enable all timeslots in the CSU
service-module t1 timeslots 1-24, speed 64
HTH,
__
Edison.
Hello Sarah,
Edit:
Hope to help
Giuseppe
Bronze
Thanks a lot Giuseppe and Edison !
Sarah,
HTH,
__
Edison.
Bronze
Just one more question.
Please consider a frame relay network.
A router is connected to frame really network by s0. This router has point to point connection to other sides which are also connected to frame relay network.
Now does LMI messages are only exchanged on physical int i.e s0 or they are also exchanged on sub interfaces?
thanks a lot!
178
