reliable static routing backup using object tracking
hello all. i'd like to confirm the following proposal before telling a customer the scenario is doable. a customer wishes to have a primary internet T1 connection, and a backup cable modem. i've been reading the PDF for reliable static routing and would like to make sure i can acheive the following config (i haven't tested it in a lab):
ip sla monitor 1
type echo protocol ipIcmpEcho 1.1.1.1 source-interface serial 0/1/0:0
timeout 1000
threshold 2
frequency 3
ip sla monitor schedule 1 life forever start-time now
track 50 rtr 1 reachability
interface Serial0/1/0:0
description - T1 connection -
ip address 1.1.1.2 255.255.255.252
interface FastEthernet0/0
description - Backup Cable Modem -
ip address dhcp
ip route 0.0.0.0 0.0.0.0 1.1.1.1 track 50
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 254
access-list 100 remark ACL to trigger PBR
access-list 100 permit icmp any host 1.1.1.1 echo
route-map PBR permit 10
match ip address 100
set ip next-hop 1.1.1.1
set interface Null 0
ip local policy route-map PBR
1 REPLY
Bronze
Re: reliable static routing backup using object tracking
I am assuming that you are pinging the far side of your serial interface in this config. if that is the case, you can still ping the /32 interace but that does not mean that the internet is reachable.
I would use either dns or http for the the SLA or ping an internet address. If I use either DNS or HTTP, I would not bother with the PRB.
222
