Webcast-Catalyst9k
remote access to vpn device
I currently have a full data T-1 that
is routed through a Cisco 1760 Router/2950 Catalyst Switch to my lan
patch panels. I am trying to provide
remote access with a SonicWall SSL-VPN 200 that I have plugged into one of the ports on my switch. I can communicate within my lan with the other computers on the lan but cannot access the ip address of the new device from any other location. Can I program the switch to allow incoming traffic on specific ports or will It have to be all of them. And how do I accomplish this?
1 REPLY
Re: remote access to vpn device
Let us know the connectvity that you have and the hows the routing is working on the LAN. Where is the new box connected, is it on the same vlan or diffrent vlan ?
Which device is doing the routing between the vlans.
Paste the config of the router.
-amit singh
238
