Community Member
Remote Console to Catalyst Switches w/AS2509-RJ
I am currently working on finding a way to remotely access our Catalyst 3548XL switches via the console port. As I understand it, I can use the Async ports on a AS2509-RJ to connect to the console port remotely. The only problem is that I don't know how to do this. Can anyone offer some configuration suggestions along with some pointers on the cabling?
Community Member
Re: Remote Console to Catalyst Switches w/AS2509-RJ
Community Member
That seems like a great solution, if I had the equipment. In the end, I found an alternate solution.
Using the AS2509-RJ I already have along with a few rollover cables, I was able to telnet to each of the 8 Async (2001 - 2008) ports after adding the following to the config:
line 1 8
session-timeout 30
location To Switches
password PASSWORD
login
modem InOut
terminal-type vt100
special-character-bits 8
no exec
transport preferred none
transport input telnet
telnet break-on-ip
telnet ip-on-break
stopbits 1
flowcontrol hardware
Community Member
I like the Lantronix serial concentrator. They are expensive but the ability to set each port on the concentrator to a corresponding TCP port I find very useful.
Justin
299
