Webcast-Catalyst9k
Remote PC Console to a Management 2950 Switch.
The main problem I am facing here now is that the devices (routers & switches ) connected to the CONSOLE SWITCH 2950 are sometimes giving me a LINE PROTOCOL DOWN error when I type SHOW INTERFACE. Why is that? How do I get round this one? I assumed it was a problem of not setting up the correct ip address scheme; ie giving another device the same ip address accidentally but then I changed the devices to their own ip address but get the same problem of LINE PROTOCOL DOWN. I dont think its NO SHUTDOWN in ip address configuration. I dont think I need clocking on ethernet connections.
So then could it be the type of ethernet I had to choose eg// FULL DUPLEX 10 BASEX during INTIAL ROUTER/SWITCH CONFIGURATION? Which I think I did.....
Re: Remote PC Console to a Management 2950 Switch.
You just try to hardcode the speed/duplex under the interface and check the physical connectivity.
Speed 100
Duplex full
Plz let me know if it works and solve your issue and rate this.
configure this on both side router/switch
278
