Remove Password encryption
majdalani
i have applied the following command in the config mode : service password-encryption
how can i remove it ? so that the passwords are no longer encrypted ?
3 Accepted Solutions
Once encrypted passwords will stay so until you cancel encryption with no keyword AND enter them from command line again.
Tarek
Collin has given exactly the right answer. But it may not seem that way when you apply the no service password-encryption command. Be aware that this command turns off password encryption. But that passwords that have been encrypted and stored in the config as encrypted will remain encrypted even when you turn off the service. The only way to get those passwords into clear text is to configure the passwords again after the service for encryption is turned off.
Rick
Rick
Andriy is correct. Since these are VTY passwords they must be removed then re-added. You could also reverse the password since these passwords have weak encryptions.
6 Replies 6
Collin Clark
With most Cisco configurations, the no keyword removes the command.
HTH and please rate
yep i know that, and i have tried that, but the password is still encrypted, i even type wr mem, closed the session, telnet to the swicth again, and it is still shown :
line vty 0 4
password 7 01100F074F
login
line vty 5 15
password 7 00071A0510
Tarek
Rick
Rick
Hi , Thanks to all.
I have understand it now.
yep i change the password once again and the password appeared again.
Thanks again,
Tarek
