removing all qos parameters
hi all, I want to remove all qos from my switch, how do i do it, it has the below
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
Re: removing all qos parameters
This looks like an output of the "auto qos voip" command, doesn't it?
Well, it might be tedious but trivial: simply copy all the lines into your favourite text editor, insert the "no " word and whitespace on the start of each line and then copy it all back to the terminal while staying in the global configuration mode.
Best regards,
Peter
yes thats correct, I tried that but most of them would not remove, I was getting errors!!
any other suggestions ?
There will be probably two or three lines that will give you errors.
Try to write them in the "no" form manually, pressing the ? mark after each keword until you see the output, then press Enter. When removing some commands, the CLI does not accept the entire line but rather a certain portion of the original line.
Best regards,
Peter
This page and replies are of
This page and replies are of little use.
I have the same problem and there appears to be no good answer for this.
I would imagine many others have this same problem.
Sorry if I am being too harsh but come on man.
Steve
Steve,
Steve,
I suggest you create a new thread with the specific problem you are having - even if it is the set of mls qos commands you want to remove - and first and foremost, post your entire switch configuration there so that we can properly assess your configuration in its entirety. It does not make sense to beat a horse that has been dead for 6 years (this thread).
Also, please understand that the replies to posts in this forum are entirely voluntary, provided by people in their free time. As much as we try to help everyone to the best of our abilities, we make no guarantees on the completeness and suitability of our answers, and you cannot expect or demand that these forums provide a guaranteed support service. It is being run by people just like you. Imagine yourself in our place, receiving feedback like the one you just wrote.
Best regards,
Peter
Got it~!~!, just had a hunch
default mls qos srr-queue output dsc
Steve
Steve,
Steve,
That's good - thanks for sharing the solution that worked for you!
Best regards,
Peter
Super Bronze
default command,huh? - neat!
What device and IOS version?  (Not all commands are available on all platforms or IOS versions.)
Device: WS-C2960-48PST-L
IOS (I believe) 12.2(52)SE
The "default" command is also good for setting a switch or router port back to the factory settings.  Not many people that I work with seem to know about it.
Example: switch(config)#default int f1/0/2
In regards to my success: even a blind chicken gets a kernel of corn every once in a while and even a broken clock is right twice a day~!~!~!
Steve
no mls qos srr-queue inputno
no mls qos srr-queue input cos-map queue
no mls qos srr-queue input dscp-map queue
no mls qos srr-queue output cos-map queue
no mls qos srr-queue output dscp-map queue
1306
