Community Member
Removing config from previously stacked 3750
I have a 3750 switch that had been part of a stack but it now on its own.  sho io int should only display ports on 1/0/* but as you can see from the output below 2/0/* is still showing.  How can I remove the old stacked config references?  Thanks.
stEthernet1/0/21     unassigned      YES unset  down                  down
FastEthernet1/0/22     unassigned      YES unset  down                  down
FastEthernet1/0/23     unassigned      YES unset  down                  down
FastEthernet1/0/24     unassigned      YES unset  down                  down
GigabitEthernet1/0/1   unassigned      YES unset  down                  down
GigabitEthernet1/0/2   unassigned      YES unset  down                  down
FastEthernet2/0/1      unassigned      YES unset  down                  down
FastEthernet2/0/2      unassigned      YES unset  down                  down
FastEthernet2/0/3      unassigned      YES unset  down                  down
FastEthernet2/0/4      unassigned      YES unset  down                  down
FastEthernet2/0/5      unassigned      YES unset  down                  down
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Removing config from previously stacked 3750
Ahhhh ... Ok.  So you want to remove switch 2?
Scroll down the config.  You erase the line that has "switch 2 provision <3750 model number>".
Easy.  In config mode use the command "switch 2 renumber 1".
Save the config and reload.
Don't forget to rate useful posts.  Thanks.
Community Member
I tried - but no luck.
lab-swouter1#sho run | i switch 2
switch 2 provision ws-c3750-24p
lab-swouter1#config t
Enter configuration commands, one per line.  End with CNTL/Z.
lab-swouter1(config)#switch 2 re?
renumber
lab-swouter1(config)#switch 2 renumber 1
There is no switch number 2 in the stack
lab-swouter1#show switch
Switch/Stack Mac Address : 0023.eacd.1600
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 0023.eacd.1600     1      0       Ready
2       Member 0000.0000.0000     0      0       Provisioned
Thank you very much for the ratings.  Glad to be of some assistance.
540
