Community Member
Removing VTP Domain configs
Hi, I configured vtp domain on our 6513 and 2950 switches. But now i wish to reverse this. However the switches don't take a 'no vtp domain' command. How do i remove already configured vtp domain configs? Thanks... and have a fantastic day!
Re: Removing VTP Domain configs
Hi Friend,
Put 6513 and 2950's in VTP trasnsparent mode.
When you configure the switch for VTP transparent mode, VTP is disabled on the switch. The switch does not send VTP updates and does not act on VTP updates received from other switches.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat5000/rel_4_2/config/vlans.htm#xtocid79804
HTH, Please rate if it does.
-amit singh
Hi Friend,
You cannot completly remove the VTP configuration from the switch. By default the switch are in vtp server mode with NULL domain.
So you can configure it back to null domain with "vtp domain NULL "and hit enter
Ankur
*Pls rate all helpfull post
Community Member
For 2950's Take the switch out of production
Try deleting the vlan.dat file from flash. and reload switch. Set the switch to the required VTP mode ie Server, transparent or Client.
205
