Community Member
replacing 3600 with 2600, 2*T1 & Ethernet
I have 2 T1 connection to branch offices coming in to my router: IOS (tm) 3600 Software (C3640-I-M), Version 12.2(21), RELEASE SOFTWARE (fc3)
the routers on both branch offices are also 3600.
I have a 2600 router that I want to use in the main office to replace the 3600: IOS (tm) C2600 Software (C2600-I-M), Version 12.1(5)T7, RELEASE SOFTWARE (fc1)
did all the configuration and connected the new router to my LAN - all works perfect.
then I switched the connections on both T1s to the new router and could ping the routers on both branch offices (I see it as L2+L3 working)
now here is my problem: I can't access any device beyond the routers, both when accessing from the new 2600 to each branch office or other way.
everything look ok and obviously there is something I'm missing - either a configuration or incompatibility of the 2600 IOS.
I hope to get a clue...
Green
Re: replacing 3600 with 2600, 2*T1 & Ethernet
sounds like a routing problem : )
Are you able to ping the LAN interface IP at the branch office from the 2600. If you don't then the 2600 mayn't have route to the LAN at the Branch Office. Compare you configuration from the 3600 with the 2600 and make sure it took all the commands.
If you are still having problems then post your configuration.
Sundar
Community Member
I did match all commands, "show run int s0" and "show int s0" look exactly teh same.
I could only ping the WAN interfaces (or telnet to them).
i guessed taht it is a routing problem but where? what should I look for?
the default gateway on the 2600 point to s0 and the only other static route point to my LAN.
Make sure IP routing is enabled in the router. I have seen some new routers come shipped with 'ip routing' disabled. And add a default route like this one and check the status;
ip route
If you are still having problems then post the configuration.
Sundar
Community Member
here is one of the serials and the routing
66.233.123.33 is the LA router WAN interface
Ethernet0/0 is my LAN interface (that is the one int that work fine)
interface Serial1/0
description Line to LA
ip address 66.233.123.34 255.255.255.252
service-module t1 timeslots 1-24
ip classless
ip route 0.0.0.0 0.0.0.0 66.233.123.33
ip route 192.168.101.0 255.255.255.0 66.233.123.33
ip route 192.168.110.0 255.255.255.0 66.233.123.33
ip route 192.168.200.0 255.255.255.0 Ethernet0/0
no ip http server
Community Member
one more clarification: how do I make sure that IP routing is enabled?
When you do a 'show ip route' you should see all those static and connected routes show up in the routing table.
141
