Replacing a backup Sup 720
ppellettiere
I am replacing a faulty sup720 on a 6513. It s the backup/hot not the
active sup. It has the same IOS on it. Is it correct that all I need to do is
remove the faulty and replace it with  the new sup and do a wr mem?
Fromwat I have read their should be no down time all connectivity
should remain stable?
3 Accepted Solutions
Reza Sharifi
It should work fine since you are replacing the Stand-by sup, but Just in case, do this during an outage window.
In addition to having the same exat IOS as your primary sup, make sure there is no config on it.
chaitu_kranthi
As long as hardware and IOS on the New Sup is same as Active one, you won't get any problems.
for additional information please refer the below link.
https://supportforums.cisco.com/thread/2004204?tstart=690#3016670
No, the primary sup will Sync the config to the stand-by.   Then "sh redu" should show that the primary is active and stand-by is hot.
6 Replies 6
Reza Sharifi
When I checked the IOS I could see there wasn't a configuration on it.
chaitu_kranthi
when the 2nd sup comes up does it check to see if it is
the backup sup ? Does it automatically download the config from the active sup?
Thank You!!!
