07-22-2014 09:01 AM - edited 03-07-2019 08:09 PM
Hello
I have a 3 switch stack
Switch Ports Model SW Version SW Image
* 1 52 WS-C3750-48P 12.2(25)SEB4 C3750-IPBASE-M
2 52 WS-C3750-48P 12.2(25)SEB4 C3750-IPBASE-M
3 52 WS-C3750-48P 12.2(25)SEB4 C3750-IPBASE-M
Switch 3 has failed so I need to replace it. (So its not the master at least)
However the above switches are all WS-C3750-48P Version ID V05 Running 12.2(25)SEB4 IPBASED and the spare I have is a WS-C3750-48-P 12.2(35)SE5 using an IPSERVICES image
Will it work if I add it to the stack ?
Eddie
07-22-2014 09:18 AM
Also have tired to obtain the Software from the Cisco download section but cannot locate it anywhere !
07-22-2014 10:32 AM
in order to get stack fully functional you will have to perform upgrade/downgrade manually, since the auto-upgrade and auto-advise features do not work if the switch master and switch that is in VM mode run different feature sets.
One option is to use archive copy-sw command. Which means that you will copy sw from stack master to switch that is running the incompatible software. Check the link bellow.
in my opinion you should consider upgrading the stack to one of the recommended and stable versions.
i hope this helps.
M
07-22-2014 09:46 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I don't know, but with that big a jump (or any difference) between IOS versions, I would be very concerned.
What you could do is copy your IOS from either of your remaining switches and run it on the replacement.
