Replacing WS-X6708-10GE to WS-X6704-10GE
I'm planning to swapping our 8-port 10Gb (WS-X6708-10GE) to the 4-port 10Gb (WS-X6704-10GE).
Would this be the proper procedure?
  1. module clear-config
  2. Remove the 10-port card
  3. Insert the 8-port card
  4. no module clear-config
  5. Reconfigure the interfaces on the new card
If interface ten 1/1 on the 10-port card is my OSPF uplink, will this also remove my OSPF and VLAN settings?
Any help would be greatly appreciated!
Jason
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hello Jason.
It's as simple as swap the linecard, module clear-config command is not even a must. I guess when you say: If the interface ten 1/1 on the 10 port meaning the 8ports linecard, is my ospf uplink, if that's the only uplink your ospf neighbor will go down, but if there's a redundant connection it will stay up. Regarding vlan configuration, vlas are saved in the vlan database, they won't be erased.
Regards.
Wilson B.
Please rate useful post.
1 REPLY
Hello Jason.
Regards.
Wilson B.
457
