Community Member
Reporting Tool for Switch Configs
All,
does anyone have a good reporting tool that can search through my configs and highlight errors within the config or highlight sections based on a Find?
I have a switch config with hundreds of ports that if certain criteria are met, that port is highlighted. Any help is appreciated.
Re: Reporting Tool for Switch Configs
according to my knowledge, there is no such tool to highlight the errors on the configuration which you will paste of ur switches/routers.
Community Member
you can use cisco works... which will show you section based config or through find option.
Rgds
Senthil
152
