Req: GLC-LH-SM SFP module converter to Ethernet via Fiber (customer End).
Dear Experts,
I have WS-3750G-12S-12  SFP port switch and GLC-LH-SM SFP module to attche in 3750G switch port.
Now i need directly connect to our customers, from 3750G Switch port SFP module of GLC-LH-SM to customers PC through Fiber.
e.g  switch 3750G port 7 attach with GLC-LH-SM SFP Module >>>> Fiber >>>> customer's Pc
so which converter i need to use which is convert from Fiber to Ethernet it is user customer end and then connect to their PC.
Also i need to know Which Fiber  patch code i need to use ???
Please help me.
Thanks in ADV,
Vaib...
1 ACCEPTED SOLUTION
Re: Req: GLC-LH-SM SFP module converter to Ethernet via Fiber (c
Check out the below link hope this helps for your query !!
http://www.cisco.com/en/US/docs/routers/7200/install_and_upgrade/gbic_sfp_modules_install/5067g.html#wp90313
Ganesh.H
Dear Ganesh,
Thank you very much for your great support
But i need Converter which is i need to put at customer end to convert ethenet to connect their pc
From my switch 3750G port which is attach in this port GLC-LH-SM >>> fiber>>> Converter ???? >>>Customer PC,
So which converter to use at customer end whic is connect to their pc
Thanks in ADV,
Vaib...
303
