09-10-2010 12:22 PM - edited 03-06-2019 12:55 PM
Howdy Cisco Community,
I am looking for some input to help me properly plan and elegantly design my logical network re-configuration. I'm specifcally hoping to hear from people that have done this before, not just theory based on documentation.
To start, here is some background and the environment setup. The infrastructure exists to host internet-facing web/app/db servers for various external clients. The primary focus here is to ensure client environments are isolated from one another. I inhereted the environment several years ago, so this restructuring has been a long time coming.
The equipment is as follows:
External ethernet internet comes in through the two 2950's, then through the ASA's and finally to the core 3750 stack. Some ~100 servers are dual-linked and trunked to diverse switches in the stack.
There is an assortment of VLAN's, but fundamentally each host is trunked to only two:
Some hosts may have a 3rd VLAN for iSCSI traffic, but this is not done over a physically seperate interface. Aside from external to internal traffic through the ASA's there is no other filtering. There is no VLAN filtering of any kind (yet)... All hosts point to the ASA for default route. Overall, host traffic is rather light (5-15% utilization) with the exception of backups.
My goals of the reconfiguration are:
My primary questions/concerns are:
Thanks for reading this far, I tried to keep this as short as possible. I am leaning towards making the 3750's the default route but am very concerned about switch load and filtering in the core.
Please ask for any additional information that may be helpful and thanks in advance for your responses.
Josh
09-10-2010 12:46 PM
Hello Josh,
I would suggest you to consider VRF lite to segregate traffic of the different customers:
shortly: each customer can be placed in its own VRF Virtual Routing Table giving you built in separation between the different VRFs
each VRF has its own end-to-end topology up to the ASA where a different VLAN subinterface is used.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/25sg/configuration/guide/vrf.html
This can greatly reduce the amount of filtering configuration and activity.
Hope to help
Giuseppe
09-10-2010 12:52 PM
Giuseppe,
Thanks for the quick response. VRF-lite looks very promising, I'm researching it further but forgot to mention that the 3750's are IP base... We may need a feature set upgrade but am checking with our vendor.
09-10-2010 12:50 PM
Josh
Josh
Some points to think about -
1) if these are separate customers then you absolutely shouldn't use the 3750 to route between vlans. ACLs are in no way comparable to a stateful firewall so each customer should be on it's own vlan.
2) Having said the above a better fit would be to run your ASAs in active/active (assuming you are not terminating VPNs on the ASAs) so each customer has it's own virtual firewall. This is what contexts were primarily designed for ie. hosting multiple customers and keeping their traffic separate. Then a misconfiguration on the firewall only affects the customer whose context you are working on. However you may need to purchase context licenses for this setup and that may not be possible ie. cost.
3) if you went with 2) a logical next step is to use vrf-lite on the 3750 to maintain separate routing tables for each customer.
The above ie. 2 + 3 is the best way to keep customer traffic entirely separate. If you can't do that then absolutely use the firewall as the default-gateway and do not route off the 3750 switch.
There are some other things as well -
1) are the web/app servers different servers from the db servers ?
2) how are the customers connecting ie. on private lines or internet ?
Generally speaking web/app servers are separate servers from the db servers. In addition it is common practice to firewall between the web/app server and the db server. I'm assuming though that each customer vlan contains the web/app and the database server ie. you do not have a database server vlan for all customer database servers ? - if you do you need to change that.
So is the traffic flow -
customer -> web/app -> db server
where the web/app is routed off the ASA and the db server is also routed off the ASA ? Or is the web/app server and the db server per customer in the same vlan so that the traffic from the web/app server can go straight to the db server without going via the ASA ? This can be dangerous as the web/app server is open to external access and if it is compromised you can then go straight to the db server and this is the server that contains the company data. That's why it's important as to whether it is internet or private line/MPLS access.
As for the management vlan, you have separate NICs in each server by the sounds of it which is good. You can filter on this vlan but personally i would concentrate on the customer facing side before worrying too much about this aspect. Obviously make sure that ip forwarding has been disabled on the servers though so you cannot go via one NIC to the other.
Jon
09-10-2010 01:15 PM
Jon:
Thanks for the detailed response. Allow me to respond with some commentary:
09-10-2010 04:10 PM
1) There are a few main issue to do with using acls rather than a stateful firewall -
i) it can get quite difficult to allow return traffic because if for example you have an inbound acl on a L3 SVI to filter traffic from clients on that vlan initiating traffic to a remote vlan that acl also affects return traffic from those clients to connections initiated from a remote vlan to those clients. Reflexive acls can alleviate some of this but i don't believe the 3750 supports reflexive acls.
ii) because an acl considers each packet in isolation ie. not as part of an existing connection all sorts of packets can be sent with different TCP flags set etc. These packets would not get through a stateful firewall. Packets like these can have undesirable effects on the server TCP/IP stack
iii) there is no capability on a 3750 using acls to look beyond the TCP header. On Cisco stateful firewalls there are application inspection pieces of code known as inspect and these can check further into the packet ie. look at some of the actual data. However having said that they are not true application proxies and they don't have full understanding of the application. A lot of SQL hacks can pass right through a stateful firewall but would not necessarily get through an application proxy. IDS/IPS also plays a part here.
So i'm reluctant to say it's okay to use acls for external customers. ACLs can be fine for internal purposes within the company but the risk is too great in my opinion for external access.
2) If you use vrf-lite on the 3750 then you could actually not worry too much about active/active and context licenses are generally not cheap. The big advantage you would still get, even with vrf-lite, is that each customers firewall can be configured independantly of the others. As i mentioned, a mistake in one firewall does not affect any other customers.
3) Thanks for clarification.
4) Glad to hear it. This does mean you will be going in and out of the same pair of firewalls for web/app to db server communication so you need to factor that in. I have been involved with a number of these type of setups and often a 2 tier firewall approach was used where the web/app servers were behind one set of firewalls and then the db server was being another set. Again this may be overkill for your situation but worth bearing in mind if the load on the ASAs gets too much.
5) Agreed.
6) You are right in what you say and this does need addressing, i just wanted to focus on the front-end first. Ideally you only want to initiate connectons to the servers from the management vlan and only from specific addresses so that in the worst case scenario if a server was compromised then they couldn't just jump to other servers because they would not be coming from one of the allowed IP addresses. Any connections initiated from the server (syslog, SNMP traps etc.) should only be allowed to the syslog/SNMP servers etc.
Access to the servers can be locked down even more by authenticating users who are authorised to manage the servers. This has the added benefit of not being IP address dependant which can be a pain if you are remotely logged in via VPN and need to access a server to troubleshoot. The only problem with this is you would need something to intercept the authentication - ASAs can do this but i'm not clear on whether you are planning to run the management vlan off the ASAs or straight off the 3750 switches.
Jon
09-10-2010 05:01 PM
Thanks again, the plan is starting to get a little clearer. I'm going to read up this weekend and may have some more questions next week.
2) I'm not quite sure how VRF-lite at the switch would work in conjuction with the ASA as you describe without getting a context ASA license. How does VRF-lite alone give us firewall mistake protection, or did I misunderstand something? VRF only applies at the switching but the VLAN's are still trunked to the ASA, correct?
6) The return traffic/reflexive ACLs was something I forgot to ask about... not a problem with the ASA. The 3750 appear to support reflexive ACLs, but I can easily see how this can get very messy which is another reason to route/filter everything through the ASA. With that said, the only switch-based filtering I'll plan for is interior to the management VLAN. Yes, the idea is only to allow connections in the management VLAN from our management servers (backup, monitoring, etc...) and a little of the opposite for traps. From what I can tell in lab testing with VACL's (vlan filter) inside a VLAN, reflection isn't a problem for some reason as it is when traversing between two VLANs??
Looks like we'll need to upgrade the switch feature set, YAMW (yet another maintenance window).
Enjoy the weekend! Josh
09-11-2010 02:48 AM
Josh
2) You simply allocate the vlan interface on the 3750 into it's own vrf and then that vlan interface is a subinterface on the ASA which you can add access-lists to etc. Not quite as separate as using contexts but pretty good to be honest.
Jon
09-13-2010 03:27 PM
If implementing VRF on the stack, shouldn't the stack then become the default route for all hosts? I understand that VRF tables can keep my customers' routes seperate, but if I want to filter between the web and DB server VLANs for the same client it would no longer route through the ASA, leaving me with ACL filtering on the stack which is undesireable, correct?
VRF seems to be for much larger environments than what I'm working with here and it would also require a feature set upgrade. Not impossible, but if I spin up a number of VLANs for each customer/host function and route everything through the ASA, this should give me the same level of seperation and filtering I believe. The ASA would be configured to prevent any traffic between different clients.
Am I on track of off my rocker?
09-14-2010 04:59 AM
Josh
Yes you are off your rocker, enough said
Seriously though yes if using vrf-lite on the stack you would generally use the vlan interfaces on the stack as the default-gateways for the clients. It depends on how you want to filter between the same customer vlans ie. if you were happy to have customer A's web/app and dbase server vlans in the same vrf then you could route between them on the 3750 and filter using acls.
This has the benefit of keeping each customers vlans totally separate in terms of routing on the switch stack.
It has the drawback of not being able to statefully firewall between the same customers web/app and dbase vlans.
You could assign each vlan on the stack to a different vrf ie. customer A has 2 vrfs one for web/app and one for dbase. If you did that you may as well simply route off the ASA.
Again the benefit is keeping each customers routes completely separate on the switch stack.
Or as you say you can simply route everything off the ASA and not have any L3 vlan interfaces for the customer vlans on the switch stack at all so the 3750 acts simply as a L2 switch for these vlans.
As Giuseppe said, vrf-lite is great for reducing the amount of acls/filtering needed on L3 devices but if you are going to control everything via the ASA and not route anything (or at least the customer vlans) off the 3750 then you don't need any acls on the 3750 anyway.
Jon
09-14-2010 09:42 AM
i noticed you have 4 x Cisco 3750G-48TS in stacked configuration,
have you ever considered using private vlans for security? could give the flexibility and security you need between clients and between your own servers and clients and the best part is this will come into play before you even hit the ASA and works at wire speed level.
