Restore erased flash in 2950
I have catalyst 2950 with erased flash and nvram. So I can't boot it. I found on cisco.com following files:
1) C2950 EI AND SI IOS CRYPTO IMAGE
2) C2950 EI AND SI IOS CRYPTO AND WEB BASED DEVICE MANAGER
3) C2950 EI AND SI IOS IMAGE
4) C2950 EI AND SI IOS IMAGE AND WEB
What I can upload to switch and how?
  • LAN Switching and Routing
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: Restore erased flash in 2950
Without a running IOS on the system, you need to use Xmodem, see instructions here: http://www.cisco.com/warp/public/473/192.html
As for the image you need to select, you need to choose what you need. Each image provides a variety of services. For list of services, go to http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH,
__
Edison.
HTH,
__
Edison.
Hall of Fame Super Blue
Edison
Sorry about this but i can never find those docs that show how the port groupings are setup on 6500 modules. If you have a moment can you have a look at this thread and if you have the doc could you post it up.
Wouldn't mind a copy of the link myself as well :-)
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbff39f
Jon
thanks!
1132
