Restric telnet access
nawas
Level 4
Level 4
I have MSFC with tons of vlans in them and I can telnet/ssh to any
vlan by typing telnet x.x.x.x. I want to be able to telnet to only
mgmt interface such as loopback0. What is the best way to achieve this?
Is it possible without the ACL?
5 Replies 5
Collin Clark
Take a look at Management Plane Protection.
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/htsecmpp.html
You'll have to use the feature navigator to see if it's available on your particular switch(es).
Hope that helps.
Mark Yeates
Level 7
Level 7
Thank guys for the quick help. I assume the this will work even if I have Hybrid or native code on my 6500. (Of course MSFC will be IOS)
MPP will be IOS only. Currently it is available in T code for routers, but you'll need to check for switches.
Not necessarily, Since CoPP is a relatively new feature it is only available on the newer IOS releases. I don't believe CatOS supports this. What version is your MSFC running?
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6642/prod_white_paper0900aecd804fa16a.html
Mark
